New Cxx7 and Cxx8 range Drum issues
  • Badhabit
    • Nov 2008
    • 8
    [CQ] New Cxx7 and Cxx8 range Drum issues
    Good day all,
    I hope someone has an answer for me.
    We have found that if you swop the K drum with any of the colour drums on the new Bizhub Colour devices, the copy quality goes straight down the drain.
    Any one else experience this?
    Regards,
    • 15066
    Re: New Cxx7 and Cxx8 range Drum issues
    Originally posted by Badhabit
    Good day all,
    Regards,
    I know you have to modify the black drum to get it to even fit into one of the colour slots. And once it is in there it doesn't produce an image.
    • Synthohol
      Certified Konica Expert
      • 5919
      sounds like Konica got sick of people going the cheap modded route and created some safeguard to prevent people from doing just that.
        • 15066
        Sounds about right. Why let techs install a $100 drum when you can make them install $300 drum that is exactly the same.
        • Badhabit
          • Nov 2008
          • 8
          Any way around this?
          It is just ridiculous to pay twice the normal price, for the same part.
          • REGSIS
            • May 2016
            • 440
            Didn't try it thou, but should be possible to buy a new black drum unit, disassemble: drum, charge roller (+ cleaner, if possible) and cleaning blade; assemble these new parts in old color drum unit casing.
            Anyone tried this?
            P.S. for 8 series only because 7 series colors are IU not drum unit.
            • Gift
              • Mar 2011
              • 2459
              There's a small plastic part sitting at the front end of the drum unit near the OPC and regulating the distance to the dv assy. It's different between col+BK but not too hard to swap... just take a close look..
              • Badhabit
                • Nov 2008
                • 8
                Hi,
                Do you perhaps have a picture showing the part?
                Thank you
                • Badhabit
                  • Nov 2008
                  • 8
                  Hi,
                  Thank you
