C224e crunching paper sound and creasing on duplex A3
  • barber782
    • Aug 2011
    • 286
    Hi guys,
    Got a problem with C224e, where the machine makes a crunching sound and creases the paper slightly on A3 duplex only. Both trays do the same.
    Checked and replaced duplex door, side door with exit unit.
    It Sounds like its catching somewhere as it enters the duplex unit.
    Firmware is up to date.
    Any ideas?
    Sent from my SM-N9005 using Tapatalk
    • 23010
    Re: C224e crunching paper sound and creasing on duplex A3
    On higher volume machines it's common to see lumps of toner collecting on the paper guides, yes both metal and plastic. On the plastic guides, a small pocket knife will scrape away most lumps of toner. On the metal I prefer the chemical solution: D-ink. =^..^=
    • Eresources
      • Nov 2011
      • 37
      Check the rollers directly above the fuser unit. There's 4 of them in a row. The plastic rollers gather toner on them over time and can cause that noise. If it's them, you might also see indentation on the pages like a fuser roller de-lamination or contamination. It's not on all of those rollers, sometimes it's just one.
      • Albonline
        • Sep 2008
        • 1153
        Originally posted by barber782
        Hi guys,
        Any ideas?
        have seen a few of the 4/e series do similar thing . the return spring on the diverter gate is too tight or the solenoid is too weak /needing adjustment . have also seen interference to movement of the gate . take a good look at the turnaround /diverter gate area.
        • barber782
          • Aug 2011
          • 286
          Will do. Was looking in that sort of area. Will report back my findings
          • barber782
            • Aug 2011
            • 286
            Looked and replace whole exit assembly but still does the same thing. Also replaced the clutch that engages the duplex rollers.
            Really puzzled now.
            • allan
              RTFM!!
              • 5462
              Is the toner fused under the crinkles?
              Always carry a pocket knife...
              Whatever
              • Gaffers01
                • May 2011
                • 335
                Start by opening the side door when the a3 paper is half fed through from the paper tray,
                and check if its coming out square (any skewing will effect A3 worse so will end up creasing badly by the time it goes through the fusing unit).
                If its not coming out square replace feed rollers.
                There was an issue with early models that the fuser exit guide was causing creasing so may need to replace the fusing unit.
                Also try printing the Lattice Pattern in service menu to see if the paper is square or not.
                • floody
                  • Mar 2017
                  • 37
                  have you tried putting fresh paper lol
                  • barber782
                    • Aug 2011
                    • 286
                    Hi, replace fuser already. Manually feed paper through to see if it catches and squared. Everything looks fine. And yes iv put fresh paper Floody.
                    • floody
                      • Mar 2017
                      • 37
                      best bet is to try crashing the machine when its printing to try and see what area its creasing the paper, have you tried it from the MP tray?
                      • Eresources
                        • Nov 2011
                        • 37
                        Recently we've been seeing the registration roller bushings start to gum up and cause the paper timing to go out. On A3 it would be worse as it's running under pressure longer. You have to remove and disassemble the unit to clean it. That's a bit of fun.
                        • Lync
                          • Feb 2016
                          • 47
                          I had a copier doing this only when duplexing A4 landscape, A3 and portrait A4 were fine. I took out the reversal unit on the top of the right hand door and in the paper feed path there was a 2mm gap on the front side and 5mm gap on the rear side looked like it was from factory. I replaced the reversal unit with another and it fixed the issue.
                          • barber782
                            • Aug 2011
                            • 286
                            Nice, will strip down reg unit and clean accordingly. Already replaced reversal unit on door, unless there is problem with that one to.
                            • mthomasebs
                              • May 2017
                              • 65
                              A good way to check if you need to even clean the registration bearings is to just manually roll the reg roller, if it feels sluggish or restricted, then definitely clean it out. If it rolls freely, the problem lies elsewhere.
