Bizhub 287, won't hold paper size.
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    The machine is a new install, 4 days old, and from the first day both of the trays have an issue with the trays holding the size. They will flip from letter to 5 1/2 x 8 1/2. I notice the new way Konica detects paper size and it looks sloppy with a lot of play in those sliding blocks. Is this a big issue on these? Anyone have a solution?
    • 23008
    Re: Bizhub 287, won't hold paper size.
    It's being fed STMT-R, correct? The machine can't feed STMT: 5 1/2" is just too short for the paper path. =^..^=
    • copyrooks
      • Oct 2013
      • 209
      Tray 1 and 2 side guide adjustment procedure.pdf
      Here's a pdf for the issue.
