Konica Minolta Bizhub 501 toner cartridge Issue
  • waqasmailbag
    • Apr 2017
    • 23
    Dear All
    As it starts it says { Adjust the Toner cartridge and close all doors } it says with the warning beep i accidentally put the blower in the toner carrying Hooper.
    any suggestions what should i do.. should i pull out the toner assembly and clean it?
    Thanks in Advance.
  • Brett GS
    • Jun 2013
    • 154
    Re: Konica Minolta Bizhub 501 toner cartridge Issue
    Best you take it out and clean the whole area and the toner bottle home sensor or you will get a c2403 code.
    • waqasmailbag
      • Apr 2017
      • 23
      Thanks Sir.i will try to pull out all the toner assembly and clean it.
      • waqasmailbag
        • Apr 2017
        • 23
        Thank you sir i pulled the assembly and cleaned it now it's ok and no code is showing up.
        Thanks again..
          • 23009
          After reading this post I am ready to pass along the title: Master Of The Obvious. =^..^=
          • waqasmailbag
            • Apr 2017
            • 23
            Sir it seams like you r pro in biz hub as v r new to this world ..... Since you are pro if you could tell me about TCR adjustment problem when v run it from the utility it gives Error 6 of you got any idea please share . One has told me to check and clean IDC AND IDCS Sensor... Your thoughts?
              • 23009
              that's certainly a great place to start. =^..^=
              • allan
                RTFM!!
                • 5462
                Dude did you really stuck a blower into the hopper hole? Hehe..
                Was this on site or at the shop?
                That is one tool i don't bring close to a copier, cause more trouble then good.
                Whatever
                • waqasmailbag
                  • Apr 2017
                  • 23
                  Actually it was the boy at the shop who did that . Fortunately I fixed that and it didn't cost me ...
                  • Synthohol
                    Certified Konica Expert
                    • 5847
