Konica minolta bizhub C360 constantly reboots when lan cable connected....
  • menosmola
    • Apr 2014
    • 95
    Hi!! I have an Konica minolta bizhub C360, the machine constantly reboots when lan cable is connected, if i disconnect cable, the machine works perfectly, but when reconnect cable, the screen turns off, and the machine reboot... any advice? Thanks.
  • Albonline
    • Sep 2008
    • 1144
    Re: Konica minolta bizhub C360 constantly reboots when lan cable connected....
    try hooking it to a laptop, or even a switch that has nothing else on it.
    • menosmola
      • Apr 2014
      • 95
      I have tried different lan cable, and tried to connect to a switch, but the problem persist...
      I forgot to say, no error codes displayed on machine...
      • guitar9199
        • Sep 2016
        • 1100
        Almost sounds like you've got a "Power Over Ethernet" issue going on. See if the client uses that, and if they can disable it for the copier's ethernet port.
        • menosmola
          • Apr 2014
          • 95
          • toshibadale
            • Apr 2007
            • 117
            Someone has a job stuck in the print que. You will have to have everyone check their que. It will not be listed in the job history on the C360.
            • menosmola
              • Apr 2014
              • 95
              I had thought about it, but too much users have access to this printer, and today had little time... tomorrow more.
              Thanks for advices. I'll tell you later if it has been possible to solve...
              • Albonline
                • Sep 2008
                • 1144
                If he hooked it to a switch, standing alone, there cant be a print job causing this. if he did hook it to a switch standing alone and the problem persists its the mfp board itself , could try the nic reset tool,but when it refuses to talk . haven't seen the reset help.
                • menosmola
                  • Apr 2014
                  • 95
                  • EarthKmTech
                    Step aside, noob
                    • May 2009
                    • 2139
                    Make sure the firmware is the latest, any print job containing illegal characters or even too many in the URL or file name will reboot the machine with early firmware.
                    seen this a thousand times even early e series firmware had this bug and usually occurred when printing from web pages etc. Couple years ago i had it twice in 1 day at 2 different sites and both were cake recipes printed off the net.
                    • menosmola
                      • Apr 2014
                      • 95
                      Firmware update fix the problem, thanks everyone for support!!
