NVRAM and firmware issue on a bizhub C352
  • blax
    • Mar 2013
    • 78
    hello!
    i have a c352 machine that restarts automatically... i replaced the DDR and the two SODIMM system memory modules to see if memory was causing the trouble, but not...
    i have the Firmware Imaging Toolkit 2006 Ver.2.5.3 and nvram recovery software but i would like to reload the firmware first (not recovery as 1st choice), but i cand find it on konica website, where can i find the latest firmware?
    another option is copy the entire hard disk from a good working copier to see if hard disk is causing the trouble, but here some users suggest load the latest firmware...
  • copier tech
    • 8196
    Re: NVRAM and firmware issue on a bizhub C352
    The firmware is not installed on the HDD, in fact you could disconnect the HDD & see if this corrects the fault.
    The HDD is only used for scanning/file store etc.
    • blax
      • Mar 2013
      • 78
      where can i find the C352 firmware?
      • Woxner
        • Jul 2011
        • 852
        remove the network cable and see if the rebooting stops. if it does its a corupt job or duplicate ip. they are not known for rebooting. most of the time it will just sit with hour glass
        • blax
          • Mar 2013
          • 78
          • allan
            RTFM!!
            • 5462
            Try connecting the machine to the network thru an additional switch an see if that works...
            Give the network settings an initialization. Make sure the network speed is not set to auto but to 100mbps full duplex.
            Whatever
            • blax
              • Mar 2013
              • 78
              it seems the trouble was solved succesfully... after replacing soDIMM, clean, remove boards, and do many another procedures, machine did not stop rebooting... the failure was the POWER ON switch.. what a pity, many hours seeing inside and the switch was the problem, i cleaned it with isopropyl alcohol and now the machine no longer reboot..
              thanks to all!
              • RRodgers
                • Jun 2009
                • 1947
                thanks to all!
                I haven't seen a bad power switch since the 7040 days. But what I have seen is bad power and bad surge protectors causing reboots.
