Lowest CPC Rate on Bizhub Press BW?
  • reckless
    • Feb 2017
    • 188
    What is the lowest CPC rate you have heard of on Bizhub Press BW?
    I am getting conflicting numbers. Some say $0.003 some say $0.005
  • methogod
    • Dec 2008
    • 922
    Re: Lowest CPC Rate on Bizhub Press BW?
    whats your monthly volume?
    • reckless
      • Feb 2017
      • 188
      100,000
      • allan
        RTFM!!
        • 5462
        The CPC of the machine will get higher with age. It starts of really low.
        Whatever
        • reckless
          • Feb 2017
          • 188
          When I was originally getting my inspection done I was told brand new machines can go for $0.00125. They are quoting me $0.008 on a Minolta Pro 1200. I currently pay $0.012 on my C6000 for black.
          I want to start printing closer to 200,000 pages a month but looking for ways to find lower my CPC.
          • allan
            RTFM!!
            • 5462
            Well what do you print? If its like flyers get a RISO.
            Whatever
            • reckless
              • Feb 2017
              • 188
              Books on a perfect binder
              • allan
                RTFM!!
                • 5462
                What is the paper weight?
                Whatever
                • Woxner
                  • Jul 2011
                  • 853
                  the c6000 is not even the same ballpark for costs even blk. .005 in normal on new machines. if its used and the machine has millions then the rate starts higher. if the volume is high enough the rate can come down.
                  • Woxner
                    • Jul 2011
                    • 853
                    riso is a dying breed. waste of time . cq is not even that great
                    • reckless
                      • Feb 2017
                      • 188
                      The machine (Minolta Pro 1200) has 19 million copies. They are offering me $0.008. Machine is running me $7k. It came with a perfect binder.
                      I am running light stocks, 6x9" paper. My covers are 10-12pt.
                      • allan
                        RTFM!!
                        • 5462
                        Not in Africa. That was only to get a good response as to what the machine needed it going to be used for.
                        If the work loads is growing or needs to take a real punch and the paper needs to be nice and flat with no waves to make for good looking books.
                        If you put a stacker with a spare trolley on a Press 1250 it makes life making books using offline binding bearable.
                        Whatever
                        • allan
                          RTFM!!
                          • 5462
                          Not on the same continent but with here the agreement would be 0.004 on a new machine that would be more like 60K.
                          Its a machine that has done a respectable amount of work and the rate would be that high to eliminate some risk.
                          Whatever
