bizhub 501
  • ranjitkr16
    • Jul 2014
    • 23
    bizhub 501
    in bizhub 501 if i perform copying from first tray its come only one sheet and shows replenish as the tray is filled with peper...and when i remove tray and keep it back again one sheet comes out ....i already change pick up roller unit , peper size sensor unit...but the same result....waiting for replys....thanq
  • Synthohol
    Certified Konica Expert
    • 5824
    Re: bizhub 501
    sounds like the black paper set actuator is broken. check your feed assy carefully. compare to working tray.
    • Woxner
      • Jul 2011
      • 848
      Re: bizhub 501
      replace the tray lock. its not holding the tray in. make sure the tray is not cracked in the lock area. common on these
      • ranjitkr16
        • Jul 2014
        • 23
        Re: bizhub 501
        yes bro it was problem with the lock...just changed and problem solved....thanq so much
        • waqasmailbag
          • Apr 2017
          • 23
          Re: bizhub 501
          [QUOTE=ranjitkr16;564425]yes bro it was problem with the lock...just changed and problem solved....thanq so much[/QUOTE
          Sir I also have 501 it gives more error codes then it prints copies latest one is TCR Adjustment problem when we perform TCR it gives Error 6 any idea how to solve this?
          One more is this machine any good in terms of image quality and reliability?
          • ranjitkr16
            • Jul 2014
            • 23
            Re: bizhub 501
            [QUOTE=waqasmailbag;566322]
            Originally posted by ranjitkr16
            yes bro it was problem with the lock...just changed and problem solved....thanq so much[/QUOTESir I also have 501 it gives more error codes then it prints copies latest one is TCR Adjustment problem when we perform TCR it gives Error 6 any idea how to solve this? One more is this machine any good in terms of image quality and reliability?
            Please change developer
