Bizhub C-353, IU Units interchange...
  • Oystercopy
    • Oct 2009
    • 623
    Hey.. does anyone know if the Drum (Imaging) units are actually INTERCHANGEABLE on this series with the other C-250/252 and maybe C-253 series? I know they're a different part number, but they physically FIT in the slot.... I have the reset chips for the units, but the machine's not running right now for me to test them. I have a main motor on order and when I put it in, I intend to try the other units, so see if they're accepted by the machine, and it will work.
    Thanks in advance,
    OC
  • copier tech
    • 8195
    Re: Bizhub C-353, IU Units interchange...
    Yes they do, simply use the old chip & fit onto the new IU
    • copyman
      Owner / Technician
      • Sep 2005
      • 4738
      It's been awhile but I think I had to change the connector from one unit to the other. Even after chipping display showed to replace IU. Not sure if it was a C253 in C353 or other way around.
      I would be very surprised if the C250/252 would work in a C353 with just the chip.
      • Oystercopy
        • Oct 2009
        • 623
        Thanks guys.. I guess I'm going to have to find out one way or the other!
        • ck1
          • 485
          C250/252 IU total difference with C253/353 . the drum and dev uint gear not same cant put in also
          • allan
            RTFM!!
            • 5462
            C200 and C253 is exchangeable, the one has the corona cleaner and the other not.
            Whatever
            • copyman
              Owner / Technician
              • Sep 2005
              • 4738
              Not to go off topic I wanted to add something that may be helpful to someone. All the toners from C200, 203,253,353 are interchangeable if you use a universal chip and cutting some fins on the toner cartd. Unlike the IU's which will all fit in each machine but give a message the toners will not, you have to cut fins on front of toner cartridge for it to fit in other models.
              • copyman
                Owner / Technician
                • Sep 2005
                • 4738
                Not to go off topic I wanted to add something that may be helpful to someone. All the toners from C200, 203,253,353 are interchangeable if you use a universal chip and cut some fins on the toner cartd. Unlike the IU's which will all fit in each machine but give a message the toners will not,  you have to cut fins on front of toner cartridge for it to fit in other models.
