Bizhub CE password Question
  • Cookr
    • Dec 2011
    • 184
    There probably is not away to do it bucase i have been searching forever but I figured id ask lol. Bought a used machine its a BH C454 and the old owners changed the CE password and now I can not get into the service mode so anyway to get around it so i can change it or is there away to change or set it back to default? thanks
    Also when i do the Stop Clear without putting in the CE it dosnt give me the reset code is that on the E series machines?
    • 14684
    Re: Bizhub CE password Question
    I just tried the "Stop C" on the C224 in my shop and it comes up with the reset code so, it works on the slow machine.
    Maybe not on the faster ones?
    • Cookr
      • Dec 2011
      • 184
      Hmm worked on my C284 also
      • copier tech
        • 8142
        Worst case there is NVRam reset firmware to clear this CE PW
        • Woxner
          • Jul 2011
          • 847
          maybe instead of 9272 4 time is just two. i know alot of kmbs guys do that
          • Cookr
            • Dec 2011
            • 184
            Yeah i tried all kinds of things lol i even used the special firmware to make it an "e" series machine that dud work but the i finally got ahold of the old company becase they uploaded a custom boot screen so i could track then down and got the code but now other weird crap is happening. So when i go in tomorrow i gotta deal with all that. Thanks though for the suggestions eveyone
            • copier tech
              • 8142
              Good work, custom logos do have a useful purpose !!!!
              • rrrohan
                • Sep 2011
                • 1977
                There is a glitch that bypasses the password screen and you can just disable CE authentication. Found this out by removing fax kit before disabling it once. Went to service mode but before i entered code it gave error regarding missing fax kit. When i pressed menu it had put me into service mode without me ever typing the code in. Havent tried it in a while so may of been patched out
                • tulintron
                  • Jul 2014
                  • 668
                  • tulintron
                    • Jul 2014
                    • 668
                    • copier tech
                      • 8142
                      • rrrohan
                        • Sep 2011
                        • 1977
                        Yeah reset means run up required again but I'd wanna fresh start anyway
