Ligth prints Konica 950
  • chivozx
    • May 2014
    • 34
    Hello,
    I can not find solution to the light impressions in a Konica BH Pro 950.
    I think it's transfer failure. I have changed the transfer wires, charge corona and charge wires.
    In the opc it is appreciated that the image is denser than the one that later appears in the paper.
    I leave you a sample.
    Thank you.
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5851
    Re: Ligth prints Konica 950
    Change your developer. It's contaminated with paper dust.
    • methogod
      • Dec 2008
      • 921
      AGREE
      • allan
        RTFM!!
        • 5462
        So the image on the drum is good but toner does not get pulled to the paper.
        What is the count on the drum and developer?
        Looks very much the same as a B751 image with a transfer current leakage.
        Make sure there is nothing touching the wires, and that the contacts are touching properly.
        You could find another HV unit...
        Whatever
          • 23009
          Originally posted by chivozx
          ... I think it's transfer failure. I have changed the transfer wires, charge corona and charge wires.
          In the opc it is appreciated that the image is denser than the one that later appears in the paper... Gracias.
          I agree with allan for a couple reasons. If the latent image is well developed the developer is doing it's job. It must be a transfer loss and there are other ways you can lose transfer:
          Perhaps the transfer separation unit does not raise close enough to the drum.
          Perhaps the corona blocks are discharging.
          Perhaps the high voltage cables are leaking. Look for burn/arc marks to the frame
          Perhaps you have an HVT failure.
          I would investigate the possibilities in that order.
          On these machines the developer rarely undertones. It almost always overtones when the developer fails. =^..^=
          • chivozx
            • May 2014
            • 34
            • methogod
              • Dec 2008
              • 921
              you can try to adjust that by upping the LD a bit...
              • chivozx
                • May 2014
                • 34
