Scan quality C554e vs C452
  • Choclit007
    • Oct 2010
    • 58
    [Misc] Scan quality C554e vs C452
    A customer with these 2 models (located at opposite ends of their office) is scanning documents with color filled in spreadsheet cells &/or other colored backgrounds & getting different results.
    The C554e reproduces the "background" colors but the C452 seems to erase it but puts a thin color border line around cells.
    Background erase was set to Darkest in both instances hoping to retain the color instead of having it erased.
    Filetype is PDF / Compact PDF
    Optics are clean.
    I seem to not be able to find any support docs relating to scan quality of this nature. Any advise appreciated.
    • 22997
    Re: Scan quality C554e vs C452
    You'll need to compare the other default scanner settings too, like:
    DPI: 200, 300, 400, 600
    Original Type: Text, Text/Photo, Photo, etc
    They will make a huge difference.
    You might also clean the scanner optics on the affected machine(s). =^..^=
    • copier tech
      • 8132
      Also bear in mind the age difference between these two models. The 'e' series will have later technology, hardware & software so I would expect that to print & scan with better results.
      โ€‹
