biz 350
  • Gab
    • Aug 2015
    • 671
    biz 350
    2 months ago I replaced developer and drum following standar procedure. After replacement image was ok.
    I performed f8 and image was perfect. But after about 40 copies i had some background and for sure it was drum.
    till now image is not ok. If i replace only opc drum is enough?
  • Synthohol
    Certified Konica Expert
    • 5849
    Re: biz 350
    is the machine using OEM toner or aftermarket/forusein dirt in a bottle?
    • Woxner
      • Jul 2011
      • 851
      Re: biz 350
      also did you reset the counters before f8 and turn machine off then on to verify they were 0 . if it crapped out after 40 coipes i would not suspect toner since you can run 100 before it adds toner. if you replace just the drum and not dev and reset drum it wil give a c2557. if you rebuilt this start with new drum unit . could also be hv unit
      • Woxner
        • Jul 2011
        • 851
        Re: biz 350
        replace transfer roller as well
