URGENTLY NEED BIZHUB C452 FIRMWARE Ver: A0P00Y0-F000-GM6-31.exe
  • AhmedChamumi
    • May 2016
    • 131
    Hi everyone,
    Please assist on the above specified.
    Thanks in advance and stay blessed.
    Best of regards,
    Ahmed.
  • rapidocument
    Multibrands Tech
    • Jul 2012
    • 381
    Re: URGENTLY NEED BIZHUB C452 FIRMWARE Ver: A0P00Y0-F000-GM6-31.exe
    PM me
    My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
    • copier tech
      • 8172
      Originally posted by AhmedChamumi
      Hi everyone,
      Best of regards,
      Ahmed.
      Why so urgently, what issue do you have!?
      • Synthohol
        Certified Konica Expert
        • 5847
        To support the feature of "cancel life stop/eliminate life notice" ill bet
        • AhmedChamumi
          • May 2016
          • 131
          Bet ya.....
          • Synthohol
            • 5847
            does not exist on SSD.
            no gm6 at all.
            1. Press the Utility/Counter key.
            2. Touch [Meter Count] on the touchscreen.
            3. Touch [Check Details] on the touchscreen.
            4. Press Stop, 0, 0, Stop, 0, 1.
            5. Press Stop, 0, C.
            6. Touch [IU Life Stop Setting] on the touchscreen.
            7. Touch [No Stop] on the touchscreen.
            8. Touch [END] on the touchscreen.
            9. Touch [Exit] on the touchscreen.
            GC6-C5 is the minimum FW to allow the no life stop.
            AFAIK it was added to base FW.
            also, im in the US region so if that version exists i dont see it in the US.
            • AhmedChamumi
              • May 2016
              • 131
              [QUOTE=Synthohol;569289]A0P00Y0-F000-GM6-31.exe
              no gm6 at all.
              also, im in the US region so if that version exists i dont see it in the US.[/QUOT
              Thank you for the info i will work on it and get back here with the result.
              Best of regards,
              Ahmed Chamumi.
