C2060 with 300gr paper...
  • topimpress
    • Jul 2017
    • 29
    hi,
    i have a new accuriopress c2060 and i have this problem when i print on 300gr width paper. on 130gr its normal.. any body know this prob
    thx
  • copytechman
    • Nov 2008
    • 947
    Re: C2060 with 300gr paper...
    Originally posted by topimpress
    hi,
    thx
    Dev units, check them for voiding, all of em
      • 23010
      I think it's pretty obvious that it's the magenta developing unit. Yellow + magenta = red. =^..^=
      • copytechman
        • Nov 2008
        • 947
        I would agree, I had a c1060 do that exact symptom but it was the yellow Dev in that case on a pretty new piece of gear.
        Regards!
        A.
        • topimpress
          • Jul 2017
          • 29
          but why on 135gr the result is perfect...???
          • Phil-Davies
            • Jul 2017
            • 5
            Have you set the correct papeweight into the machine as the image looks unfused.
            • copytechman
              • Nov 2008
              • 947
              The machine uses different belt / Dev speeds based on weight. The heavier the stock, the slower the speed, at lower speeds the Dev doesn't fill the mag roller effectively if low on Dev.
              Regards
