Bizhub 25e and envelopes
  • Qball
    • Jun 2013
    • 127
    [Misc] Bizhub 25e and envelopes
    My customer is printing envelopes from the bypass on a 25e. From day 1, the envelopes will wrinkle despite the bypass being setup properly for envelopes.
    These are the envelopes in question. They have another 25e that we tested and it, too, wrinkles the envelopes.
    Is there something that I'm missing that I can try to help this situation?
    Thanks.
  • Synthohol
    Certified Konica Expert
    • 5892
    Re: Bizhub 25e and envelopes
    That's right. They will wrinkle.
    Too many tight turns. Nothing you can do other than try to tuck the flap in first or get better envelopes made from like 24lb+ paper.
      cheap envelopes are " roll folded " meaning the folds aren't flat... when going thru a hard roller fuser ( a non-film fuser ) the folds are pressed flat causing the wrinkles. Have your customer switch to a higher quality " flat fold " envelope and you should see a marked difference. and NEVER let them leave the rear flap open on an envelope... that could cause timing issues if the flap doesn't hit the sensor arm properly.
      • dave novak
        • Oct 2013
        • 10
        Konica has a bulletin on wrinkled envelopes
        • femaster
          • May 2011
          • 1519
          This is the ID of the bulletin: KBA01400107
            • 30477
            Buy HP printer
              Buy HP printer
              but it needs to be one with a "fuser film" and not the hard hot roller.
              • Qball
                • Jun 2013
                • 127
                • Hansoon
                  • Sep 2007
                  • 3391
                  Not having access to the bulletins, I would love to see a copy of it since I have exactly the same problem at the moment.
                  Hans
