Regarding replacement of MFPB on bizhub 363
  • goldencup
    • Nov 2008
    • 366
    Hi, i have a machine bizhub 363 with defective MFPB. i check the Parts List Manual and the Part Number is A1UD H021 02 (kindly correct if wrong part#).
    I would like to ask if the MFPB of bizhub 363 are all the same?(120VOLTS and 220VOLTS). Also for example, if the machine bizhub 363 is from Europe but the replacement MFPB will came from China. Any additional information and advice will be gladly appreciated.
    Thank you very much.
  • Synthohol
    Certified Konica Expert
    • 5839
    Re: Regarding replacement of MFPB on bizhub 363
    i think they are up to A1UDH02108 for 363.
    i only show that one for the 363, the other MFPB in the parts book is for a 223/283.
    • copier tech
      • 8165
      Yes my European manual shows A1UD H021 02 (only for the 363 & 423)
      Like synthohol says latest p/n ends in 08
      • goldencup
        • Nov 2008
        • 366
        thank you all for your comments.
        • lazymangr
          • Feb 2017
          • 115
          whats the problem and you want to change the board?
