Bizhub c224e - Error code: C- c212
  • michal0110
    • Apr 2017
    • 6
    [Error Code] Bizhub c224e - Error code: C- c212
    Hey,
    My printer: Bizhub c224e
    Error code: C- c212
    When: downloading scans through printer website
    So I can send something to printer and print it, also I can scan something to printer hdd. Problem is with downloading scan.
    When I want to download scan through web it says something like "you can't do it, error" and the printer shows error C- c212.
    Maybe someone know what can be the problem?
    Thx for help!
  • Max
    • Oct 2011
    • 561
    Re: Bizhub c224e - Error code: C- c212
    Try firmware
    • michal0110
      • Apr 2017
      • 6
      Is there any other way to repair?
      • copier tech
        • 8174
        Try another browser, chrome is usually reliable.
        What firmware & function version is the machine on?
        if still on factory you will have various issues.
        • laitang
          • Nov 2012
          • 627
          You need reinstall the loadable device driver
          • michal0110
            • Apr 2017
            • 6
            I tried on IE and the same.
            Firmware:
            ROM Version
            MFP Card Version A5C10Y0-F000-GD3-E4-400
            MFP Controller BOOT Program A5C10Y0-1E00-G00-04(00)
            MFP Controller Linux Base Linux-2.6.26.8-rt16
            MFP Controller Kernel Program A5C10Y0-1C00-G00-51
            MFP Controller SubSet A5C10Y0-1F00-GC1-G0(00)
            MFP Controller A5C10Y0-0100-GD3-E4(00)
            Operation Panel Message Data A5C10Y0-8100-G00-E4-400
            Fax Board Controller1
            Fax Board Controller2
            Engine Parameter A5C10Y0-0054-G00-01
            Engine BOOT A5C10Y0-0055-G00-00
            Scanner A5C10Y0-0023-G00-30
            Printer A5C10Y0-0050-G00-25
            ADF A3CF0Y0-0024-G00-12
            Finisher
            RU
            ZU
            Panel CPU A55V0Y0-8900-G60-00
            DSC1
            DSC2
            Loadable Device Driver1 A2XK0Y0-A520-G00-02(00)
            Loadable Device Driver2
            SD
            Voice Data
            Movie Data A5C10Y0-C000-G00-00
            Dictionary Data A5C10Y0-B100-G00-00
            OCR Library
            Panel Sound Data A5C10Y0-C200-G00-00
            MFP Controller Thread Image Parameter A5C10Y0-8B00-G00-01
            MFP Controller PIC Image Parameter A5C10Y0-8A00-G00-01
            MFP Controller System A5C10Y0-1000-GD3-E4(00)
            MFP Controller Print Controller A5C10Y0-3000-GC2-W2
            MFP Controller Print Controller Font A5C10Y0-3F00-G00-W0
            MFP Controller Print Controller Demo Page A5C10Y0-3E00-G00-01
            MFP Controller MIO A5C10Y0-5000-G00-E3(00)
            MFP Controller PIC A5C10Y0-8200-G00-91
            Hmm can you write me how to do it?
            • michal0110
              • Apr 2017
              • 6
              Finisher
              RU
              ZU
              DSC1
              DSC2
              SD
              Voice Data
              OCR Library
              Can you tell me how to do it?
              • laitang
                • Nov 2012
                • 627
                A2XK0Y0-A520-G00-02 is loadable device driver or C224 not C224e.
                Depend on authentication unit installed on the mfp: AU-102 or AU-201, you need uninstall old driver then reinstall new driver.
                Perform your provider.
                • laitang
                  • Nov 2012
                  • 627
                  Movie Data is old, latest is A5C10Y0-C000-G00-30
                  • oldminolta
                    [ATTACH]37326
                    • Woxner
                      • Jul 2011
                      • 851
                      its a card authentication error. load the loadable driver with a usb in service mode under loadable driver
                      • EarthKmTech
                        Step aside, noob
                        • May 2009
                        • 2139
                        I had this error code on a machine sharing a power strip with a 1960's fridge at a school, it kept happening every few weeks and corrupting the hdd even with a new one. Once the machine and the fridge were separated the issue no longer occurred. It wasn't the card reader or the loadable device driver, it was the unreadable hdd itself resulting in the code. In my case it was likely massive voltage spikes on the power line every time the old fridge started and stopped.
                        (KM card reader and papercut MF in use)
                        • michal0110
                          • Apr 2017
                          • 6
                          I got new firmware, now it is:
                          ROM Version
                          MFP Card Version A5C10Y0-F000-G20-M1-990
                          MFP Controller Kernel Program A5C10Y0-1C00-G00-76
                          MFP Controller SubSet A5C10Y0-1F00-G00-M5(00)
                          MFP Controller A5C10Y0-0100-G20-M1(00)
                          Operation Panel Message Data A5C10Y0-8100-G00-M0-990
                          Fax Board Controller3
                          Fax Board Controller4
                          Scanner A5C10Y0-0023-G00-33
                          Printer A5C10Y0-0050-G00-31
                          ADF A3CF0Y0-0024-G00-16
                          Finisher
                          RU
                          ZU
                          DSC1
                          DSC2
                          SD
                          Voice Data
                          OCR Library
                          MFP Controller PIC Image Parameter A5C10Y0-8A00-G00-05
                          MFP Controller System A5C10Y0-1000-G20-M1(00)
                          MFP Controller Print Controller A5C10Y0-3000-G01-47
                          MFP Controller Print Controller Font A5C10Y0-3F00-G01-41
                          MFP Controller Print Controller Demo Page A5C10Y0-3E00-G00-81
                          MFP Controller MIO A5C10Y0-5000-G00-U5(00)
                          MFP Controller PIC A5C10Y0-8200-G00-B5
                          But I still got the error.
                          I should say that before the problem came, I installed card authentication device.
                          • cooke123
                            • May 2019
                            • 3
                            thanks for that is was the card reader driver, uninstalled then installed all ok
