Minolta C3102
  • digicor
    • Jul 2008
    • 1159
    Minolta C3102
    How do I re set the fuser and transport roller unit to trip the machibne so i can re use the units? I have been told this can be done to get a second use out of them.
    THanks
  • 10871087
    • Jan 2005
    • 1062
    the units are fused. I forget what size they are.
    • jjw23
      • Sep 2008
      • 36
      yes there is a fuse on both of them you need to replace. On the fuser you have to take it apart carefully to get to the fuse which is covered by black tape. Then the transfer belt has a small bulb fuse that is behind a small panel, very easy to find.
      • digicor
        • Jul 2008
        • 1159
        what size is the fuse? I found it , is it the 1/8 pico fuse i use in my rebuilds for the dI rebuilds?
        • jjw23
          • Sep 2008
          • 36
          i use the 1/16 green fuse from newark sku 12J4187
          • digicor
            • Jul 2008
            • 1159
            thank you
            i appreaciate the help.
            • jjw23
              • Sep 2008
              • 36
              oh and make sure to soder it on, so it has a good connection.
