How do I re set the fuser and transport roller unit to trip the machibne so i can re use the units? I have been told this can be done to get a second use out of them.
THanks
yes there is a fuse on both of them you need to replace. On the fuser you have to take it apart carefully to get to the fuse which is covered by black tape. Then the transfer belt has a small bulb fuse that is behind a small panel, very easy to find.
