do you turn KM6500 power off when finish your work?
  • alan2016
  • Woxner
    • Jul 2011
    • 853
    Re: do you turn KM6500 power off when finish your work?
    hope you have ac in the garage. if you cant level this with the feet then use wood blocks with the leveling feet. if you are not trained you will be in trouble trying to service this. you have to do so many things in the right order otherwise everything else is off. this is not your basic copier. it also needs to run alot of copies to make it run properly. you can turn it off if you dont use it. shut the conntroller down first. This is not cheap to work on. pm is 2000 bucks dealer cost and you will never get the life out of the drums and dev and coronas so add extra cost. even more often if it sits or not used with 50000 color a month. 30 k might be ok
      • 23010
      No. Leave the switch On and let it go to sleep.
      If you mean casters, I would say that's not a good idea. The machine must be levelled to work properly. I would suggest building a slightly raised platform with a 3/4" plywood deck that is level. Keep in mind that the accessories must be rolled away from the base machine to service. If you build a platform 1" bigger the the copier's footprint (like I've seen plenty of people do) the accessories have to be lifted off of the platform to service, and they're not light. It would be better if the platform was 3' to 4' longer end to end. Another concern is that you garage is probably not climate controlled. You'll want your machine in an environment between 60F to 80F and 30% to 50% humidity at all times. You'll have a lot of problems otherwise.
      Yes it is important to level up the paper feed unit. Being un-level will cause jamming.
