Bizhub 227 will not ...
  • acusso1234
    Tecnico
    • Dec 2008
    • 250
    problemchild
    Bizhub 227 will not print.
    No Rj45 lan jack lights. no error or codes in service call information. Move to different drop problem continue, hooked up laptop on both straight and crossover cables no lights. Can loopback machine ping machine successfully. Couldn't ping know operating valid ip addresses. Reset all connectors to Mfp board, uninstalled Hdd, then re-installed problem continues. Unit is warranty really don't want to replace Mfp is there's a alternated solution. Yes copying functions work place with another printer used same ip address works fine.
    ... In the minute that you're thinking of giving up, think about why you lasted so long ...
  • Woxner
    • Jul 2011
    • 841
    Re: Bizhub 227 will not ...
    if you cant connect in all cases its the mfp. you can try and do a network reset in service mode but i think you mfp is a gonner.i have seen machines ping but mfp is still bad. you should have link lights
    • Synthohol
      Certified Konica Expert
      • 5807
      admin mode network settings, is everything enabled as it should be?
      • problemchild
        Replace mfp board all is good
