C360 duplex jams J-7216
  • mascan42
    • 480
    [Jamming] C360 duplex jams J-7216
    If anyone is familiar with the C360, the duplex diverter gate is non-powered on this machine. Paper coming up from the fuser pushes up on the gate, and is guided to the exit, then the guide drops back down by simple gravity. Paper being reversed passes over the top of this same gate, in the lowered position.
    What seems to be happening with my machine is that it's doing both at the same time. Paper is still being reversed over the top of the gate when another page comes up from underneath it, and jams. I can hear the exiting paper crash into the gate while the reversing motor is still running. This only happens with portrait letter size paper, since the spacing of the sheets is different for landscape.
    All of the exit guides including the diverter gate have been replaced, and it seemed to work for a couple of months, but now it's doing the exact same thing. Any ideas?
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5745
    Re: C360 duplex jams J-7216
    please refresh my memory, are the exit rollers an orange sponge material?
    i had many issues when the sponge rollers start to crumble. the paper being duplexed does not return into the door fast enough it slips.
    the other issue was the lower paper sensor in the duplex door would stick and throw off the timing.
    good luck.
    • mascan42
      • 480
      No the rolls are hard grey rubber. The entire right door and transport assembly have been replaced, which solved the problem, but only for a couple of months.
        • 8107
        Does the machine have the internal finisher FS-529 ?
        • mascan42
          • 480
          No it's the floor-standing finisher, FS-527. And the paper doesn't get anywhere near it. It jams before reaching the exit rolls.
            • 8107
            J-7216 is a finisher jam
            • tech51
              • 846
              Had exactly this fault a while back. In my case it was a dirty sensor on the entry to the finisher bridge unit.
              • mascan42
                • 480
                It's been replaced.
                • allan
                  RTFM!!
                  • 5459
                  The rubber on the switch back unit rollers?
                  Whatever
