Key Counter On Bizhub 283
  • gavrielx
    • Oct 2015
    • 57
    Hi everyone,
    i just connect a Coin mechine to Bizhub 283.
    i configure it to "Keycounter only" My problem is in the next situation:
    if i have credit to copy only 5 pages and i try to print 6. the mechine pulls out 5 pages and Sticking the sixth page with "Paper Jam" Error.
    I would love to get suggestions to deal with the issue if it is possible.
    tanks
  • Woxner
    • Jul 2011
    • 841
    Re: Key Counter On Bizhub 283
    you need to adjust the time out on the coin machine.
    • oldschool
      • Mar 2007
      • 245
      Key counter I/F vendor is the setting used with a coin box connected to the key counter.
      Jamex Tech Support: Saving the world one phone call at a time.
      • Synthohol
        Certified Konica Expert
        • Mar 2016
        • 5807
        what happens if you just select vender 2 bottom right instead.
        for nothing else just to give it a shot.
        • gavrielx
          • Oct 2015
          • 57
          The mechine layouts all the pages and then close.
          if i have crdedit for 5 and i do 7 the mechine print all the 7
          • Synthohol
            • Mar 2016
            • 5807
            damn, at least it didnt jam
            thanks for trying it, i hoped it would have helped.
            • oldschool
              • Mar 2007
              • 245
              Vendor 2 works with a specific interface only. "Key counter I/F vendor" should work correctly. What happens if you use that setting only.
              NOTE:If that doesn't work, set dip sw 35 - 0 Stop print operation when key counter is removed.
              0x00 - Stop print operation immediately [default]
              0x01 -Stop print operation after paper inside the machine is ejected.
