Biz C224e, DF-701 ADF issue when scanning
  • copyman
    Owner / Technician
    • Sep 2005
    • 4750
    Please see attached pic. This is the "dual scan" ADF not the DF-624 regular ADF.
    Has lines on both sides only when scanning with ADF. Internal test pages and copies look fine.
    When I first got there is was doing it on copies & scanning through ADF. I adjusted the horiz adj screw on the right hinge and copies looked fine. Had customer try scan and lines still there, a little better but still there.
    Tried changing edge erase settings, etc. but didn't work.
    Any help appreciated.
  • mo0651
    • 1054
    Re: Biz C224e, DF-701 ADF issue when scanning
    Do the ADF zoom adjustments.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4750
      Thank you sir! I was thinking it looked either slightly zoomed in or out.
        • 23010
        I think I would take it a step further: the full image adjustments:
        Print ratio main-scan and sub-scan
        Print centering main-scan and sub-scan
        Scanner ratio main-scan and sub-scan
        Scanner centering main-scan and sub-scan
        Scanner voids
        ADF ratio sub-scan
        ADF centering main-scan and sub-scan
        I usually find that none of those adjustments are perfect. and if you start at the wrong point you end up repeating the same adjustment ... repeatedly. =^..^=
        • SAR
          • Jul 2009
          • 203
          Try doing the mixed original size adjustment too. I remember a tech bulletin mentioning copies being shrunk if this adjustment was not done.
