C1070 C-2824
  • MVPunisher
    • 209
    C1070 C-2824
    Error
    C-2821 (Y), C-2822 (M), C-2823 (C) or C-2824 (K)
    Root Cause
    Charging potential Vh terminated abnormally.
    Workaround/Fix
    To troubleshoot:
    1. Check the connection of the process carriage drawer connectors.
    2. Access I/O check mode 51-xx. It should be ON. If not, replace the subject part.
    • xx=00 (Eraser lamp/Y - EL Y)
    • xx=01 (Eraser lamp/M - EL M)
    • xx=02 (Eraser lamp/C - EL C)
    • xx=03 (Eraser lamp/K - EL K)
    3. Check the connection of CN160/CN161/CN162 (Printer Control board) and wiring for the connectors. If any problem is found, correct it.
    4. Check if ICP16 on the Printer Control board (p/n A1RF H050 0D) is OPEN. If so, replace the problem board.
    5. If the cause could not be specified by the above steps, replace the parts in the following order.
    • Printer control board
    • Drum potential sensor/Y/M/C/K (p/n A1RF R747 00)
    • Eraser lamp/Y/M/C/K (p/n 65AA 8307 0)
    • Wiring (p/n A1RF N123 03 - Main Body Wiring /3, p/n A1RF N147 00 - Transfer Wiring /1 and p/n A1RF N151 00 - Toner Detection harness /1)
  • MVPunisher
    • 209
    Re: C1070 C-2824
    I must add that after replacing the black developing unit it did run for a half day.
    • Issac-brock
      • Jan 2015
      • 61
      Re: C1070 C-2824
      Originally posted by MVPunisher
      Error
      Root Cause
      Workaround/Fix
      To troubleshoot:
      Had similar on a C7000 where I did not plug the black charger in all the way....drove me crazy with codes.
        • 23003
        Re: C1070 C-2824
        There's an adjustment that you must do any time you clean or touch the IDC sensors. Auto-something something ... I'll check. =^..^=
          • 23003
          Re: C1070 C-2824
          Sorry so long:
          It's Machine Adjustment > Printer Adjustment > Color Registration Auto Adjustment (run up to [3] times).
          • MVPunisher
            • 209
            Re: C1070 C-2824
            Yea I run the Auto gamma and that Color Registration adjustment you speak of everytime I touch anything.
            I have swapped entire carriages, K Drum, K Developer unit, charge, prcb, color reg assy. ]
            The machine we move it to still does not code out. This one still does. Laser or Wiring (backordered) is my plan. Really wooping me.....
            • MVPunisher
              • 209
              Re: C1070 C-2824
              This machine is in my office. We have a printshop out front. We have 2 of them so I can swap parts if you have any suggestions.
                • 23003
                Re: C1070 C-2824
                My main suggestion is: don't touch the black laser if you don't have to.
                All the color registration and image adjustments are based on the position of the black laser. Move it, and you'll spend a lot of time doing adjustments (even if you just take it in and out).
                It could be a laser. =^..^=
