bizhub c253
  • coastal copier
    • Aug 2017
    • 6
    [Error Code] bizhub c253
    Hello everyone!! This machine was calling for a cyan and magenta iu right after customer changed both toners c and m. The copy quality was good so i replaced the iu chips and then it coded with a c2552. So i replaced both iu units with new ones and the code keeps coming back. Any ideas? the code means cyan toner is over 11%
    • 23009
    Re: bizhub c253
    Originally posted by coastal copier
    ... the code means cyan toner is over 11%
    That's a good start. Now how do you view current TCR values? It's there in the manual. =^..^=
    • copyman
      Owner / Technician
      • Sep 2005
      • 4712
      Re: bizhub c253
      Sounds like they thought the message was for C & M toner when in fact it was for the C &M IU's. Did you shake the Image units & toners really well. Toners need to be shaken 10-20 times and IU's need to be shaken "side to side" while keeping level. I also tap on IU's while shaking to loosen up the developer. This is really important especially if boxes were stored on their side or stored for a long time. This is why the IU boxes are shaped funny so box can't stand on their side, but I have seen people still stand box on their side!
      • coastal copier
        • Aug 2017
        • 6
        Re: bizhub c253
        i looked in level 1 history but it shows all o% then it codes out. i guess because the machine never goes ready
        • coastal copier
          • Aug 2017
          • 6
          Re: bizhub c253
          I did shake the iu's but i guess its worth a try to do it again. Thanks
            • 23009
            Re: bizhub c253
            Do the motors fire up? Without the developing motor agitating the developer it won't properly read TCR. Maybe a System Error Reset is in order before you can diagnose further? =^..^=
            • coastal copier
              • Aug 2017
              • 6
              Re: bizhub c253
              i did not ck the motors i will do that on monday thanks. I did trouble reset multiple times but not system error reset ?? is that different? I have never done a system reset
                • 23009
                Re: bizhub c253
                Same thing, just in a different menu. =^..^=
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4712
                  Re: bizhub c253
                  you can watch the motors operate with exit cover left off while running machine. I think if motors were not turning it would throw a motor code.
                  • coastal copier
                    • Aug 2017
                    • 6
                    Re: bizhub c253
                    ok thanks for your help
                    • coastal copier
                      • Aug 2017
                      • 6
                      Re: bizhub c253
                      ok thanks ill ck them monday
