C224e Color printing problem
  • Synthohol
    Certified Konica Expert
    • 5740
    #16
    Re: C224e Color printing problem
    Originally posted by jamaicapepe
    Hello again my friend.
    How to change skewing and registration settings?
    hey, if you donate to this site ill give you the service and parts manual.
    no BS, ask anyone here i ALWAYS come through.
    (I do not work for or own this site, i just want to see it self supporting to the point ads are not necessary. )
    • AjitN
      • Mar 2009
      • 287
      #17
      Here you go! You can see the magenta like shadow in the EZ letters
      and also in the next picture in the hand and the brown triangle.
      [ATTACH=CONFIG]37592[/ATTACH][ATTACH=CONFIG]37593[/ATTACH]
      I am bit confused, may be expert from forum can help me.
      As seen in images EZ have magenta shift but in same image that ( I am not able to recollect) "NIKHTHS" does not show any magenta shift. Both are in white text so how come EZ shows shift and bottom one does not have ant shift. Is it possible?
      Really confused, Please let me know & thanks in advance
      • habik
        • 2013
        #18
        Originally posted by AjitN
        I am bit confused, may be expert from forum can help me. As seen in images EZ have magenta shift but in same image that ( I am not able to recollect) "NIKHTHS" does not show any magenta shift. Both are in white text so how come EZ shows shift and bottom one does not have ant shift. Is it possible? Really confused, Please let me know & thanks in advance
        IMHO
        The image is either created from two sets of colours.
        The above is with Black using CMYK
        The bottom with Black using K only.
        or
        The mirror on magenta laser is at slant and gives issues only on the top half of the image.
        Firmwares HERE
        • allan
          RTFM!!
          • 5459
          #19
          Do you get P-codes like P-21 in combination with a color drum?
          look for an oil can on the screen and touch it to show the warnings.
          Whatever
