C224e Color printing problem
  • jamaicapepe
    • Sep 2017
    • 15
    Hello to everyone,
    The last few days I have a problem with my printer.
    When I print in color, there are some vertical lines which I suppose
    are from the old drums but also there is a thing like shadow (mostly red color)
    Do you think it is from the drum too (I have already ordered one)
    Or is there something else I can do (e.g. A calibration or something like that)
    Best Regards,
    Sakis
  • beehappy
    • Aug 2017
    • 2
    Re: C224e Color printing problem
    Possible the cleaning blades don't clear corectly, are dirty or worn-out.
      • 22999
      Maybe a image sample might help? =^..^=
      • jamaicapepe
        • Sep 2017
        • 15
        Here you go! You can see the magenta like shadow in the EZ letters
        and also in the next picture in the hand and the brown triangle.
          • 22999
          Simple color registration. Have you done a stabilization and gradation? =^..^=
          • jamaicapepe
            • Sep 2017
            • 15
            I did color registration and gradation before....
            I have +6 max registration but the red still leaves a shadow
            • Synthohol
              Certified Konica Expert
              • 5808
              check your internal test patterns, make sure its not just a shit image file.
                • 22999
                I don't think we're talking about the same thing. Enter service mode > Process Adjustment > Stabilization & Gradation...
                • jamaicapepe
                  • Sep 2017
                  • 15
                  Yes I have already done that.
                  And also after that I have played with color registration patterns.
                  It did it for cyan and yellow but the red color is not fixed.
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4648
                    Most likely the drum unit is causing the magenta background & lines. Could also be the developer unit but usually the drum. Especially since you posted the drums were old.
                    • jamaicapepe
                      • Sep 2017
                      • 15
                      Thanks for the advice my friend. I am waiting the new drums on Tuesday so i will change them and inform everyone here how it goes.
                      • vijaysharma
                        • Sep 2008
                        • 61
                        Hi,
                        Just interchange the magenta drum with cyan drum if the lines change into cyan lines check cleaning issue of drum unit.
                        Regards
                        • jamaicapepe
                          • Sep 2017
                          • 15
                          Originally posted by vijaysharma
                          Hi,
                          Regards
                          Thank you for the advice my friend. I will check that also.
                          • nassor
                            • Sep 2017
                            • 30
                            Try again skewing and registration
                            • jamaicapepe
                              • Sep 2017
                              • 15
                              Hello again my friend.
                              How to change skewing and registration settings?
