Bizhub C220 is making strange noise + Video
  • christmu
    • Sep 2017
    • 3
    [Misc] Bizhub C220 is making strange noise + Video
    Hey,
    I bought a used Bizhub C220 recently. The copier has only done 120000 copies yet. All the consumables are relatively new and I thought it would be a great deal :-)
    Unfortunately this machine is making a strange noise. For me it sounds like rattling wheels inside the machine.
    I recorded a video of this noise:
    The noise occurs in different situations:
    1.) At startup it takes relatively long
    2.) During printing
    3.) now and then if the copier is turned on, but not used. (the noise takes a relatively short amount of time, but I guess the copier is adjusting something)
    4.) If someone opens the front-cover or the door on the right
    Thanks a lot,
    Christian
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: Bizhub C220 is making strange noise + Video
    Know that noise anywhere.
    transfer belt cleaning section is blocked.
    clean it out and unblock the chute to the waste toner bottle.
    15 minute job.
    problem solved.
    • christmu
      • Sep 2017
      • 3
      Wow!
      first answer and totally right, took me around 10-15 minutes and the problem seems to be solved.
      Thanks a lot,
      Christian
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        Originally posted by christmu
        Wow!
        Thanks a lot,
        Christian
        Once you've done it a thousand times like I have you know the problem before the customer even finishes saying hello.
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5015
          Video save you a lot of time.
          • mjunkaged
            • 386
            Will replacing the belt fix it as well?? Or is it down inside the machine where it's clogged?
            • copyman
              Owner / Technician
              • Sep 2005
              • 4726
              Belt is usually fine and only needs to be vacuumed out. There was a bulletin on this about cutting the plastic inside the chute or something like that.
              The right way to clean it is taking trans belt out, removing the cleaning unit (2 screws) and vacuuming out. Or if you want to cheat you can just vac where it goes into waste box. Doing it the right only takes 10 mins more.
              • copier tech
                • 8179
                Same issue but different story with the C353 series!
                • EarthKmTech
                  Step aside, noob
                  • May 2009
                  • 2139
                  Theres a short pipe in the front of the machine from the waste output of the belt to the top left of the waste box.
                  if this is not cleaned out your new belt will get backed up too.
                  I've only ever seen the belt back up without the pipe also being blocked when its long hair thats gone into the waste section of the belt.
                  In hot climates like where I live its always the front pipe that gets blocked first and then the belt waste has no where to go.
                  This issue is still present in 4, e & 8 series no where near as common though. If you're never seeing it, you're living in a cold or mild climate
                  • SAR
                    • Jul 2009
                    • 203
                    They came out with a new style seal on the waste toner pipe that is supposed to help prevent the clogging. you could try replacing it if you continue to have issues. Waste Toner Pipe (p/n A0EDF36001).
                    • rrrohan
                      • Sep 2011
                      • 1977
                      Clean the filter on front cover. Poor ventilation is the main cause for toner blockages. Most techs are to lazy to do this
                      • peterxu256
                        • Jul 2014
                        • 110
                        A very good suggestion to all users and techs. most of commercial printers(floor model) from small business are located at tiny space, needless to say ventilation, users are sitting beside often( no sensitive to ozone gas, ignore to listen to a kind suggestion from a good tech. Virtually no user/customers to follow the user manual instruction.
                        Back to the above case, if keep running with such kind noise, eventually the Belt will break into a piece. poor image quality come out, then looking for repairing...
                        • tech51
                          • 846
                          And while you're at it, take off the back covers and clean off the fuser fan filter and the filter for the cooling fan under the board box.
                          These always get overlooked....
                          • bearthor
                            15 minute job.
                            problem solved.
                            Is there a video or picture guide where this is done?
                            I emptied the "trash" under the "powder cartridges". Not sure what else to do or how.
                            • Gael
                              • Oct 2019
                              • 18
                              Hello,
                              I have exactly the same problem than christmu.
                              EarthKmTech c
