Bizhub c284 "lines of shame"
  • arahael
    • Mar 2013
    • 97
    [CQ] Bizhub c284 "lines of shame"
    Hello ! I have problem with KM. I done installation step by step more than 4 times. Blue and magenta stripes still stay only on copies... What to do next ?
  • richmods
    • Aug 2013
    • 91
    Re: Bizhub c284 "lines of shame"
    are you sure you set the time zone correctly? skipping this step will cause lines.
    • arahael
      • Mar 2013
      • 97
      Done.... No idea what next brrrrtr
      • Cookr
        • Dec 2011
        • 184
        one time I didn't have the ADF serial number programed in and in cause the lines but it was on a B&W machine im pretty sure. Good luck
        • Vikingrepairguy
          • Mar 2017
          • 21
          Have you made sure to do the non image erase check, where you turn the lights down and run the test???
          • arahael
            • Mar 2013
            • 97
            I made erase check, with ADF open. also when i go in service mode orange light on left blinking.... i have 2nd copier near and there is no blinking - but work all
            • copier tech
              • 8153
              I have seen this a few times over the years on the c224 (non e) for me updating the fw then starting the install again fixed the issue.
              The process has been shortened on the later e models.
              • arahael
                • Mar 2013
                • 97
                Problem is solved: before next install i had to memory clear. Then search this forum and found that non "e" and "e" have not same install manuał.
                1. Display adjust>time setting in administrator> install datę
                Thank you for your assist
                • copier tech
                  • 8153
                  Thanks for the update
