Bh 601 J3204
  • rbalanjr
    • Sep 2013
    • 4
    [Jamming] Bh 601 J3204
    Hi I have a bh601 that doesn't want to cooperate. I replaced the duplex motor, exit sensor after the fuser, replaced the exit solenoid and exit drive clutches. Are you guys have anymore recommendation? I also put in a rebuild fuser to cover my base but to no avail. Thanks.
    • 14972
    Re: Bh 601 J3204
    I don't remember what a J3204 refers to on this machine, but I do remember there is a paper driven guide on the exit side of the fuser that would cause problems. It has light spring on it. Sometimes the point where the spring attaches to the guide will break off and cause jamming.
    • manuelcorrea
      • May 2009
      • 46
      Re: Bh 601 J3204
      Remove exit section and check for bent mylars
