Bizhub c 360 no display
  • smiley
    • Aug 2008
    • 615
    Good day guys i have this machine that has no display only the blue color led light and orange start button appear on the control panel. I try to clean the ram and replace it but never change. Any one incounter this can help me what i have to do next.please.
    there is no glory without sacrifice
  • copyman
    Owner / Technician
    • Sep 2005
    • 4765
    Re: Bizhub c 360 no display
    Try updating firmware. Also could be bad NVRAM.
    • REGSIS
      • May 2016
      • 435
      When you turn ON the machine (main power and sub power) does the machine warm up normaly?
      Can you print?
      I had only one problem like this and after replacing DVI cable it was all normal again.
      Also you can try switch control panel from another machine. It's easy.
      • smiley
        • Aug 2008
        • 615
        Hi guys this machine dosnt boot up or warm up. I try to replace the ram. Butit dosn't work.
        • Zesti
          • Jun 2009
          • 309
          Re-flash the machine.
          Was there any power surge?
          • smiley
            • Aug 2008
            • 615
            good day guys just an update to this problem i replace the prcb still no good then replace mfp board with the new ram. still doesnt boot up. only orange color on start button turns on.
            • smiley
              • Aug 2008
              • 615
              Can you print?
              friend can you please help me where i can see this dvi cable? thanks
              • Techlife
                • Mar 2015
                • 27
                Originally posted by smiley
                dvi cable? thanks
                White cable that runs from machine to the display panel
                • smiley
                  • Aug 2008
                  • 615
                  thanks techlife i will try to replace it.
                  • EarthKmTech
                    Step aside, noob
                    • May 2009
                    • 2139
                    just plug it in directly between the panel and mfp external socket to test if its the problem. If it doesnt work you just saved a hell of a lot of work for nothing.
                    • smiley
                      • Aug 2008
                      • 615
                      guys are the control panel of 360 are same with 451?
                      • REGSIS
                        • May 2016
                        • 435
                        Could be.
                        If you have time you can take both apart to check if there's any differences.
                        I only know that coltrol panels from c360 series and 423 series are not entirely same, but that doesn't mean that they don't work on different model.
                        I think that you can do no harm if you try panel of 451 on c360. The worst thing it can happen is that panel would not work properly, or hang up.
                        On the other hand they might be excatly the same. You can check part number in both manuals if they match.
                        • Albonline
                          • Sep 2008
                          • 1153
                          A02EM70001 BH C253/C550/C650/C451
                          A0P0M70603 C220,280,360
                          A0P0M70603 B223/423/360/c452
