bizhub pro 951
  • AdrianSKY
    • Nov 2017
    • 2
    [Error Code] bizhub pro 951
    Hi,
    I recently join this company, they have a b951 with these two errors, c-c2211 and c-c136.
    The fella replaced the printer controller board and did firmware.
    However the code persist.
    The c-c2211 is definitely the intermediate toner hopper motor as we swapped it to check on another and it produced the same code on another machine.
    Any help will appreciated.
    Thanx
    • 23009
    Re: bizhub pro 951
    I must not understand correctly.
    You swapped the toner hopper to another machine and the problem moved, yes? If yes, I think we can safely assume that the problem is in toner hopper assembly. So the question is ... what? =^..^=
    • mircea
      • Feb 2014
      • 70
      Re: bizhub pro 951
      Originally posted by AdrianSKY
      Hi,
      Thanx
      i think you are asking for c-c136 code right?
      did your fella try to reinstall firmware for both oacb and icb ? i1 and p firmwares should be reinstalled.. if not .. you will have to replace both boards. and also check the wiring between the boards ...
      best of luck
