C451 can't set/change paper tray size
  • pozar
    • Apr 2017
    • 20
    Cheers
    M
  • mayorg
    • Feb 2015
    • 53
    Re: C451 can't set/change paper tray size
    Open the tray 2 check the back tray and check the sensor
    Sent from my SM-G925P using Tapatalk
    • pozar
      • Apr 2017
      • 20
      The service manual doesn't note what I should offer as a sacrifice to keep the printer running. How many human tears would suffice you think?
        • 23009
        The copier gods require a blood sacrifice, preferably yours. Most of the machines that I have bled on work better ... I don't know about tears. I don't do much crying over copiers. =^..^=
        • habik
          • 2013
          Loose connection or stuck holder. It may come back. Lube the slider with sensors. Check for proper connections.
          Sent from my Mi A1 using Tapatalk
          Firmwares HERE
          • pozar
            • Apr 2017
            • 20
            You wouldn't have an image or illustration of how the sensor might look? I'm not sure what to look for. In the FSM (40Mb PDF) on page ≈620 there are images showing the tray, but I don't see anything related to sensors there.
            • Zesti
              • Jun 2009
              • 308
              Buddy there is paper inside behind paper trays. Happened when there is jammed paper in tray and without removing properly.
              • pozar
                • Apr 2017
                • 20
                Nope, that happened last
                • Zesti
                  • Jun 2009
                  • 308
                  Happened with me last week on C550. Found a paper droped behind tray blocking tray connector to sit in body. I' sure u have same situation.
