C364 Save COPY images as TIFF??
  • gtr5320
    • Dec 2016
    • 32
    Save COPY.FAX.PRINT images to TIFF on computer?
    目前只有PDF
    • 23007
    Re: C364 Save COPY images as TIFF??
    Scans can be saved in .tif file type if you like. That might be a yes, if understand your question correctly. =^..^=
    • gtr5320
      • Dec 2016
      • 32
      [QUOTE = blackcat4866; 584729]掃描可以保存為.tif文件類型,如果你喜歡。如果正確理解你的問題,那可能是肯定的。= ^ .. ^ = [/ QUOTE]
      NO SCAN ,Copy image backup
      Copy the copy image to your computer
      • Synthohol
        Certified Konica Expert
        • 5824
        copying an image to a computer is called a scan.
        you can use SMB scanning to "copy" the document/image to a Tiff file in the folder you want.
        the file type can be created as a jpg, tiff xps or like you say 目前只有PDF (as it is now)
        • gtr5320
          • Dec 2016
          • 32
          [QUOTE = Synthohol; 584733]將圖像複製到計算機稱為掃描。
          • Synthohol
            • 5824
            after copying or faxing or printing, backs up the file to your computer
            It seems that you do not know that function
            that function does not exist, you are asking the impossible.
            • rrrohan
              • Sep 2011
              • 1977
              you can Photocopy and have it scan to PC at same time
              id explain it but this youtuber already has.
              Only way i know of to save print jobs is to have a print driver monitor. We use PaperCut but probaly have cheaper options out there.
              • Synthohol
                • 5824
                No friggin way!!
                I'll be a monkey's uncle.
                I stand totally corrected.
                • gtr5320
                  • Dec 2016
                  • 32
                  I was able to scan the backup to my computer while copying or faxing
                  But the file format machine default PDF, no way to change tiff
                  The method is not the youtube method above
                  • Synthohol
                    • 5824
                    at 1:20 in the video you can change to tiff no?
                    • CompyTech
                      Super Tech
                      • Feb 2011
                      • 706
                      I can confirm this works. Never even knew this feature was built in.
                      • Synthohol
                        • 5824
                        me neither, i would have gone to the grave believing it was not capable.
                        after all the turkey i had some crow to eat after this thread!
                        • rrrohan
                          • Sep 2011
                          • 1977
                          Our product trainer showed me about a year ago. I didn't know about it for years neither
