Bizhub 654e
  • antone
    • Oct 2014
    • 344
    Bizhub 654e
    Jams when duplexing ...jam code J30-03 ...any 411
    Sent from my SM-N920V using Tapatalk
  • habik
    • 2013
    Re: Bizhub 654e
    Flag out of position in branch section? Or bent photointerrupter holder. Sticky gate.
    Eject rollers seizing up? (Slow reverse)
    Reg actuator worn ( short timing/loop on plain duplex).
    Dust removers full of paper dust / reflective sensor soiled.
    Which tray is it doing it with mostly?
    Sent from my Mi A1 using Tapatalk
    Firmwares HERE
    • Synthohol
      Certified Konica Expert
      • Mar 2016
      • 5829
      Re: Bizhub 654e
      there is a little rubber/foam silencer pad on the left side of where the duplex gate contacts.
      i have seen this pad cause jamming from the gate either getting stuck in the wrong position or when it swells from heat it wont allow the gate to open all the way.
      i scrape it off with my nail and it will click louder during duplex but jams are gone.
        Re: Bizhub 654e
        replace foam pad with some E Tape... just like you would an HP Plate Solenoid be sure to clean the gate that connects to pad with IPA
