Bizhub c284e Ce password reset?
  • mrfuser
    • 1627
  • rrrohan
    • Sep 2011
    • 1977
    Re: Bizhub c284e Ce password reset?
    If you glitched your way past the password screen just turne off CE authentication. Otherwise you have to call KM for reset code
      • 15069
      [QUOTE=mrfuser;586107]
      • Woxner
        • Jul 2011
        • 854
        if you got into service mode then hit stop 0 c then touch ce paswword you can just turn this off
        • mrfuser
          • 1627
          I updated firmware and reset it then to default
          • Synaux
            • Mar 2012
            • 1224
            FrImware resets CE pass? Is this a "new" feature? Pretty sure that didnt work on older models.
            • mrfuser
              • 1627
              It does and when you go back into service mode you can set it as you like.
              • Synaux
                • Mar 2012
                • 1224
                WHAT?
                What in the world are you talking about?? You cannot get into CE pass without getting into SM FIRST--which requires the CE pass!
                The basis of your inquiry is "Bizhub c284e Ce password reset?".... Someone correct me if I am wrong, but this person is fused (get it?).
                Mind Blown....
                I need Phil to come here am set me straight! (perhaps I am fundamentally mistaken?)
                • mincopier
                  • Dec 2015
                  • 289
                  Firmware resetting the password as a tool is not likely. It might be possible that it reset a corrupt switch that allowed the password to work though. Other than that to reset the CE Password with the CE Authentication on you would normally need a NVRAM reset tool. Sometimes going through the "Trouble Reset" screen can allow you into service mode without a password. You can then use the "Stop, 0, Clear" to get into Security mode to reset the CE Password, Turn it off, or reset the Administrator password.
                  • mrfuser
                    • 1627
                    • tsbservice
                      Field tech
                      • 8081
                      I may be wrong but maybe some of the guys vented because your thread name?
                      • mrfuser
                        • 1627
                        QUOTE=tsbservice;1198199]I may be wrong but maybe some of the guys vented because your thread name?[/QUOTE]
                        • Synaux
                          • Mar 2012
                          • 1224
                          I might have gotten carried away.
                          However, I am too dumb sometimes to keep all this stuff in my head:
                          If people here--people I respect--start saying that on the newish models that a FW will reset the CE pass enough times, I am liable to start believing it (or at minimum start questioning what I thought I already knew--which can be arguably even worse). Moreover, the guys/gals new to the industry or techs that work on predominately on other brands do not stand a chance reading such things. It kind of amazed me that no one jumped on this from the onset...
