Re: bizhub C224 has C2152 error code
Hello at all,
yesterday I had the same code. Replacing with a new belt didn't succeed, after cleaning PS39 the malfunction still appeared!
Pull the belt out and check if the gear to engage CMY 1st transfer is possible to turn.
Sometimes just reseating the belt sorts this issue.
I had it once when replacing CL8 Clutch without taking the belt out of machine. After reseating belt all went away.
Sent from my Mi A1 using TapatalkLeave a comment:
Have seen toner cover the retraction sensor. Ended up getting a thin rubber hose to blow it out. To get to the sensor by stripping could take a hour or three.
The issue was more common on the C360 machines.
Have changed out control board as well but was probably an ICP.
There is a clutch i forgot to plug one other time...Leave a comment:
check IPC3 on printer control board. if you already changed the belt .Leave a comment:
I have never seen this code on this model. Actually last time I saw it was a C253 which had a lot of issues with this trans belt code. Since you did everything mentioned in the serv manual then only thing I can think of is re-initializing the machine?Leave a comment:
Cannot figure this out. The fuser motor turns when the machine powers up. I have checked sensor PS39 and I get a change of state when it is interrupted. I have tried another transfer unit and the code still comes up. I am not that experienced with Konicas so the book maybe saying something I do not understand. I need to get the machine working again. I would be very thankful for any help.
