C364e shrinking PDF scan to email?
  • guitar9199
    • Sep 2016
    • 1100
    Hey gang.... Another puzzler.I have a C364e that when the customer scans to email, the image of the pdf file created is actually shrunk by a fairly substantial bit...maybe 5-7%. It doesn't do that when making a copy.Current settings are...300 dpi- Auto color- Standard PDF. I had to enable edge erase to remove the border on the trailing edge of a scanned pdf until I figure out the fix.Has anyone else seen this, and if so what can I do to adjust it? The client is a bit.... "Persnickety" about their image quality.Thanks in advance...
  • BHM
    • Feb 2011
    • 131
    Re: C364e shrinking PDF scan to email?
    I have seen scanned pdf files that would not open in full page view but the actual image was fine.
    If the scanned pdf is printed out is it reduced as well?
    • guitar9199
      • Sep 2016
      • 1100
      Yes it is.
        • 23010
        What reduction? Auto reduction? You can default it to 100%. =^..^=
        • smokeetr
          • Apr 2011
          • 19
          there is a software switch setting for that don't remember which switch but I remember you have to hex it to 40
          • guitar9199
            • Sep 2016
            • 1100
            It's already defaulted to 100%... but for some reason everything comes back reduced.
              • 14972
              Is your client's PDF program reducing the scans? Have you tested it by sending a scan to your own laptop?
              • guitar9199
                • Sep 2016
                • 1100
                They're opening the PDF with Adobe Reader. It's multiple computers on their network, and they are scanning to email...not SMB/desktop scans.
                • guitar9199
                  • Sep 2016
                  • 1100
                  Did you ever locate this setting? I'm still looking for an answer, but not having a ton of luck on my end.
                    • 14972
                    When you scan to your own email what is the result?
                    • guitar9199
                      • Sep 2016
                      • 1100
                      Identical result..PDF slightly smaller than the original (maybe 5-8%?). Customer is using a Gmail account for SMTP, and just recently noticed the problem. Their machine was replaced 6-7 months ago with a refurbished unit, but nothing was said until last week or so.
                        • 14972
                        Could it be an A4 to letter issue?
                        • habik
                          • 2013
                          Have you tried factory defaults for Scan function?
                          Reloading firmware? Or downgrade and then upgrade? Changing function version down and up?
                          Does the self diagnosis come OK in Service mode?
                          Sent from my Mi A1 using Tapatalk
                          Firmwares HERE
                          • guitar9199
                            • Sep 2016
                            • 1100
                            Machine was set to defaults when installed...they only recently noticed the shrinking of the files, so it's likely been happening since it was delivered.
                            We installed the most recent firmware before we even brought it out to the customer. All diagnostics check OK... Strangely, it only happens on scan to file/email. If you make a copy, everything is well within specs....just those pesky PDF files are giving me fits.
                            • BHM
                              • Feb 2011
                              • 131
                              Sorry if I missed it but what happens if you select tiff format? There are some pdf compression settings that you can try if it is only when doing a pdf.
