Bizhub c3850 broken scanner belt
  • mrfuser
    • 1617
    I have client did just move two of these machines to a new office and both of them have a broken Scanner. belt
    Does anyone have a part number for the belt and how hard is it to replace
  • allan
    RTFM!!
    • 5462
    Re: Bizhub c3850 broken scanner belt
    Just re-crimp and add glue to the joint. I fix that on the spot.
    Whatever
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      Part number A121PP0N02
      Piece of cake to change, keep one in stock.
      Same belt used in c35, c3350 & c3850 variants. All versions snap the same way.
      • mrfuser
        • 1617
        Thanks all for the tips. Any idea why they break?
        • Woxner
          • Jul 2011
          • 842
          because when they moved them they slammed the scanner to one side most likey.
          • JR2ALTA
            • Feb 2010
            • 2031
            Its not easy for me, I spent an hour chasing my tail the first time. There's a pdf in this thread to help
            Konica Minolta bizhub C35 Scanner Belt Replacement.
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              The belts snap always at the end where the belt is folded over itself to form a loop and is crimped. The brass crimp ends up cutting all the way through the belt. Crap belt design, clearly just an existing off the shelf belt being modified to suit a specific application instead of being designed from the ground up for the task.
              • B0265
                • Jan 2007
                • 718
                KOM160433
                To improve the quality of the Scanner Belt in the Optical Unit, the following changes have been implemented
                for the Caulking Parts and Tension Coil Spring of the Scanner Belt.
                <Caulking Parts>
                - Change the Material (Brass => SUS)
                - Change the Tip Shape (Wave Shape => Flat)
                - Width Change of the Caulking Parts (4mm => 6mm)
                - Defines the hight of the Caulking Parts (2.9mm)
                <Tension Coil Spring>
                - Change the inner diameter of the hook part in the "inner diameter 5.55mm"
                Due to the above changes, the Parts Number of the Scanner Belt has been changed
                New Parts No.A121PP0N02
                • copyrooks
                  • Oct 2013
                  • 208
                  Added the bulletin
                  • EarthKmTech
                    Step aside, noob
                    • May 2009
                    • 2139
                    Aannnd, they still snap.
                    300+ of these in one customer, revised part number still breaks, regularly.
                    • srvctec
                      Former KM Senior Tech
                      • Oct 2009
                      • 827
                      Yeah, it's just a crap design since the strands in the belt only go lengthwise (when they fail, there are always strands sticking out from the inside of the belt, like it just pulled apart, sliding on the strands). I think what would help is if they need to make them with X pattern strands inside the belt and then change the crimp.
                      Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                      • mrfuser
                        • 1617
                        Thank you all for your tips! Great info to have. I ordered new belts, and before installing them I added a little dab of super glue gel to where the tabs are bent over the belt just to give it a little more strength. Seems to be working fine for the moment.
                        Take care all !
                        K
                        • gitana1983
                          • Mar 2009
                          • 141
                          Originally posted by B0265
                          KOM160433
                          <Caulking Parts>
                          Quick question, I have already replaced the belt but now is the scanner which is faulty but in the manual only shows the whole assembly, how can I get part number just for the scanner?
                          • habik
                            • 2013
                            What codes are you getting?
                            Sent from portable device using fast cheapset!
                            Firmwares HERE
                            • mrfuser
                              • 1617
                              Start a new thread
