Help with Firmware Updates All Konica Minolta but now C224e
  • fadsamniote
    • Apr 2016
    • 80
    Hello !
    I have duzens of C224e firmwares versions but I dont understand what should I use because for example in Ricoh the newer versions are identified with a letter from A to Z , "A" (Old Version) and "Z" (New version).
    How works in Konica Minolta ? Some firmwares are Multilanguage and have a .bat file , for example I want spanish how I do to select "spanish_language.bat" ?
    Example:
    A5C10Y0-F000-G20-63.exe
    A5C10Y0-F000-G20-A9
    A5C10Y0-F000-G20-C8
    A5C10Y0-F000-G20-G9
    A5C10Y0-F000-G20-K2
    A5C10Y0-F000-G20-K5-100-CHECKSUM-d64d
    A5C10Y0-F000-G20-K6
    A5C10Y0-F000-G20-K9
    A5C10Y0-F000-G20-M0
    A5C10Y0-F000-G20-M1
  • srvctec
    Former KM Senior Tech
    • Oct 2009
    • 827
    Re: Help with Firmware Updates All Konica Minolta but now C224e
    Log into KonicaMinolta's website and they are all arranged neatly, in order and showing the date they were put on the website, unless you aren't a certified KonicaMinolta technician. If that's the case, I'm not sure how you were able to obtain any firmware at all.
    Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
    • fadsamniote
      • Apr 2016
      • 80
      Hello !
      I allready understand fw versions, its the same has Ricoh.
      Can I upgrade for example C224e Firmware from FW-G20-E4 to FW-G20-J6 without installing the FW-G20-G9 that its the version before FW-G20-J6 ?
      • copyman
        Owner / Technician
        • Sep 2005
        • 4718
        On the 4 series unless special f/w I always use the latest at top of the list. Although a little confusing with the (LK-101) in title of some f/w. See my post below in this thread.
        • Woxner
          • Jul 2011
          • 850
          one thing to remember abouit firmware updates is that sometimes soft sw changes need to be made to make it effective. somtimes funtion level as well. so reading the pdf that comes with it is important.
          • Max
            • Oct 2011
            • 560
            M1 is the latest. On f/w screen you can select aditional languages
            • copyman
              Owner / Technician
              • Sep 2005
              • 4718
              F/W has always been confusing to me! Looking at M1 at top of the list it has (LK-101). I remember a Konica rep told me if upgrading just regular f/w to use the first one down the list that does not have (LK-101). Unless of course the machine is having issues with the LK-101 options than use the latest with LK-101. I'm still confused
