C253 vs c353 iu and dv
  • mrfuser
    • 1627
    Does anyone know if a c253 and c353 use same iu and developer units?
    • 15068
    Re: C253 vs c353 iu and dv
    They are keyed differently. You may be able to put a C353 chip on a C253 IU and vice versa. I have never tried it.
    • paulrid
      • Nov 2011
      • 206
      Only difference is the chip I've swapped many around.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4788
        Most aftermarket reset chips are universal and fit both c253 & 353.
        Same thing with aftermarket "toner" chips, they will fit both C253 & C353 toners but you have to modify the front cover to fit in the other model.
        • antone
          • Oct 2014
          • 344
          Not the same
          Sent from my SM-N920V using Tapatalk
          • mrfuser
            • 1627
            Actually they are and worked fine just swapping chip
            • copyman
              Owner / Technician
              • Sep 2005
              • 4788
              I used to have around 100 of this series in my accounts and I swapped IU's from C253's to C353's and other way around all the time with just changing the chip. Never had an issue.
