biz 501
  • Gab
    • Aug 2015
    • 671
    biz 501
    OPC drum has scraches and i must replace it. Do i have to replace developer too? if i replace only drum and blade and not developer do i have any problem?
  • mrwho
    Major Asshole!
    • 4299
    Re: biz 501
    If the print quality is ok (except for the drum scratches) and if the developer isn't over life, then, if I remember correctly, there should be no reason to replace the developer.
    Anyway it would be wise to take a developer bag with you just in case.
    Mascan42
    Ibid
    • Synthohol
      Certified Konica Expert
      • 5822
      Re: biz 501
      if the DV life is under 60% you may get away with it.
      just do your LD1s and LD@ adjustments. and reset the drum and blade counters.
      i usually set them so the first shading blocks just shows up just over the line. saves for overtoning and the mess it becomes.
      • antone
        • Oct 2014
        • 344
        Re: biz 501
        U can replace drum blade
        Sent from my SM-N920V using Tapatalk
        • KMFLT3CH
          • May 2017
          • 230
          Re: biz 501
          You can replace the drum and blade without the developer, np.
