bizhub362 adf wont pull
  • garrycmsi
    • Jun 2015
    • 22
    [Jamming] bizhub362 adf wont pull
    I have a bizhub362/df620 that does not pull from document tray reliably. I have cleaned and lubed feed clutches,cleaned rollers still will not always pull.
    any ideas?
    Thank You
  • Albonline
    • Sep 2008
    • 1131
    Re: bizhub362 adf wont pull
    any ideas?
    Thank You
    replace the one ways.
      • 14356
      any ideas?
      Thank You
      In the main drive there is a one-way gear that starts to slip. I have sometimes been lucky enough to just get some alcohol on it and have it work. Otherwise you will need to get that gear off and clean it. Also clean and scuff the shaft it runs on.
      You need to take the rear cover off to get at this one-way gear.
      • Albonline
        • Sep 2008
        • 1131
        with the work involved just replace it.
