bizhub 420 flashing LED ethernet port
  • libmar
    • Feb 2018
    • 8
    Hello to all
    I have this situation on my photocopier I have updated the firmware (thanks to Synthohol a great one) but I have not solved the problem.
    according to you which can be the cause?
  • Gift
    • Mar 2011
    • 2459
    Re: bizhub 420 flashing LED ethernet port
    Does it flash even if there is no network cable plugged in?
    If not - try connecting direct to your notebook via crossover cable to bypass the customers network enviroment.
    • libmar
      • Feb 2018
      • 8
      no
      I try and let you know
      ps I verified that not even the USB and parallel port work
      the PC does not reveal any photocopier
      • libmar
        • Feb 2018
        • 8
        no ... they always flash and the copier will not connect
        • tech51
          • 846
          What was the original fault that caused you to update the firmware?
          Did it print before the update?
          Also, what colour are the lights on the port?
            sounds to me that your IP addy doesn't match the network scheme...
            but it's really hard to diagnose due to the LACK of INFORMATION GIVEN.
              • 23008
              It would help a lot to know what it is you are trying to fix.
              If the problem is that you cannot print ... do you have the print server option? =^..^=
              • rrrohan
                • Sep 2011
                • 1977
                • libmar
                  • Feb 2018
                  • 8
                  for a period of time the copier after switching on the leds flashed and it took more than half an hour to connect to the network I thought it was a firmware problem and I reinstalled the firmware but the problem persists and now does not connect to the network the ip address is all ok I checked on the copier panel all the parameters are ok but the leds of the network card flash green and orange alternately
                  which pins?
                  • rrrohan
                    • Sep 2011
                    • 1977
                    network port pins
                    • libmar
                      • Feb 2018
                      • 8
                      this bizhup 420 is crazy
                      this morning the copier came out with the error c-c183
                      I used the program isw for the firmware but it locks both with USB and parallel cable I do not know what to do
                      I am attaching photos
                      if anyone has any ideas, please come forward thanks
                      • kenpio
                        • Dec 2015
                        • 201
                        Was not there a chip that was installed in the main board to enable it to print? I think it was called IC-204. Can you print a test print from the copier?
                        KEN
                        • libmar
                          • Feb 2018
                          • 8
                          in chips there is ... the photocopier is locked for c-c183 error
                          • kenpio
                            • Dec 2015
                            • 201
                            C-C183 The machine type mentioned in
                            the software is different between
                            the overall control and the image
                            control.
                            • libmar
                              • Feb 2018
                              • 8
                              Resolved
                              it was the network cable ... it worked on other PC and printers mind on the konica no
                              changed bizhub network cable started working
                              ps last question (then no more stress :-))
                              what is the latest firmware for bizhub 420?
                              thank you
