Konica Minolta c252
  • mamqa
    Konica Minolta c252
    Hello! I have an C252, but an problem.
    When i start te MFP the hour glass just shows up, and after multiple on/off on main switch the machine starts. I have re-setted machine but no change. So, can an reflash/update of the firmwire fix this? Do sombody have firmwire and tool for this job?
    Thanks.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4765
    Re: Konica Minolta c252
    Firmware could fix this but first you should try formatting the hard drive, or replacing. Also could try new Ram.
    For firmware update you need a 128mb compact flash card ("UN"formatted), Kon/Min imaging toolkit, and latest firmware.
    I have hard drive and memory if you end up needing them. Or if you ever need anything else I have 2 working very low meter C250/252 for parts.
    • mamqa
      Thank you for Answer.
      The harddrive is formatted and deactivated. I have plans to try new RAM. But want to try Firmwmare update first, do you have the toolkit and file?
      • copyman
        Owner / Technician
        • Sep 2005
        • 4765
        PM me with your email. I can send you F/W file but don't think I have the toolkit. Maybe you can find on google?
        • mamqa
          You got PM 😊
