C1070
    • 22930
    #16
    Re: C1070
    There is a small percentage of developer starter in the toner cartridge toner. The starter is abrasive, so it's not ideal, but you won't be using a lot, so go ahead. If you are doing a lot of low fill images like black text, you may find that the primary transfer cleaning belt is not getting adequate lubrication by the toner. There are settings that you can make to create additional toner patches between the print images to provide more lubrication for the cleaning blade. Does this sound like the situation? =^..^=
