C1070
  • stuckmx
    • Nov 2017
    • 36
    C1070
    Hi folks
    Today i swap c1070s intermediate t. Belt cleaning unit with a new one.. but forgot to remove red screws from it.later realized it.. itb has no scratchs or whatsoanything im getting this white lines on print that wasnt before
    Itb belt seems okay no scratch
    I clean idc sensors
    Ran blade setting mode
    Ran color registrations
    Checked fuser
    Replaced itb cleaning unit
    Checked drums and nothing
    Cant seem to find where the error is to make all the prints get this banding or white line on every color
    Thanks in advance
    • 22997
    Re: C1070
    Probably a dirty grid or two from piling up all that toner.
    Clean the primary charge units. =^..^=
    • stuckmx
      • Nov 2017
      • 36
      Re: C1070
      Thanks a lot for answering
      Yesterday i tried cleant all the charge grids
      Cleaned also dust proof glasses and even run the machine without them
      I blower brush around where the dust proof glass goes and the color reg sensors
      Checked drum and int transfer belt and no visible tear or mark
      Looked around trying to look dust or particles shouldnt be there and nothing
      Rewrite firmare clean all paper tray settings
      Factory reset some settings (as its a low vol machine 292k only)
      Problem still there
      This machine is driving me crazy
        • 22997
        Re: C1070
        I suppose you could have dirty laser optics. I'm assuming it only affects cyan. =^..^=
        • stuckmx
          • Nov 2017
          • 36
          Re: C1070
          thanks again once for replying
          nope, it does on every one and single colour print and with bypass tray too, as seen is 2 pictures next (test no53)
          even in only black happens too
          isnt fuser either
            • 22997
            Re: C1070
            I haven't seen it on this model, but I suppose there might be a hair or fiber dragging along the primary transfer belt, displacing the latent image. I've seen the same effect from a toner buildup on the upper fuser guide, also displacing the unfused image on the paper entering the fuser. Just guessing now. =^..^=
            • Woxner
              • Jul 2011
              • 838
              Re: C1070
              if its on every ind. color it wont be drums or slit glass or laser with the same image. if its front to back also same answer. did you prime the cleaning unit with #2 yellow toner and turn the belt before you put it in? even though it has a blade mode it still has to be primed first. i doubt all drums coronas slit glass are doing the same thing. . put another belt in and prime it. or try the old belt. dont use the toner in the bottle. you need to order the yellow toner for priming. it has no dev in it. i have seen techs with this problem by not priming
              • stuckmx
                • Nov 2017
                • 36
                Re: C1070
                thanks bro, must look very well then, by the 2 times i have seen check this model with cellphone led lamp cant seem to find any
                the image enters like this to fuser so the problem is in earlier process but cant find it physically... will try to use setting powder on the itb to see if helps
                yeah the line goes edge to edge, i didnt prime it, it became like on the way to here got spill out on to roller, but didnt prime it
                i dont have any other belt, machine fairly new 295k prints only, never been replaced belt, under optimum conditions.
                you mean prime the belt or the cleaning unit? with oem item KM "SETTING TONER"?
                thank you
                  • 22997
                  Re: C1070
                  Originally posted by stuckmx
                  you mean prime the belt or the cleaning unit? with oem item KM "SETTING TONER"? ...
                  The toner in the toner bottle has a percentage of developer, to replenish developer loss and extend the life of the developer. That developer included in the toner is abrasive and should not be used for priming. Konica Minolta sells yellow toner only for priming drums and transfer belts, in a small bottle. Does that make sense?
                  • Woxner
                    • Jul 2011
                    • 838
                    Re: C1070
                    this is the part # for the setting toner. A50UPP0100. use it on the blade and the belt. Setting powder may cause problems so use this toner
                    • stuckmx
                      • Nov 2017
                      • 36
                      Re: C1070
                      yeah i meant by that Setting Tonner as in my post bro
                      Would it harm if i use C8000 setting tonner? A1RFPP0000
                      THANKS TO YOU BOTH FOR YOUR ANSWERS
                        • 22997
                        Re: C1070
                        It will work fine, no harm. Probably identical. =^..^=
                        • wjurls
                          • Feb 2017
                          • 494
                          Re: C1070
                          Did you replace the 2nd transfer roller and discharge brush?
                          • tech51
                            • 846
                            Re: C1070
                            There's a guide on the adu bed that sits directly below the It belt. I believe its purpose is to prevent trail edge flick on lighter paper. It has a brown coloured mylar guide which can get rippled and start to touch the belt which can cause white lines as it scrapes the image from the belt before image transfer. I remove the guide (two screws) and have yet to see the fault it's supposed to prevent.
                            • Honpress
                              self service
                              • Oct 2022
                              • 62
                              Re: C1070
                              Hello Blackcat,
                              I found this old post, because I'm having problems with the transfer cleaning blade. Somehow it's curling up, I have never had this before. It's an older one, so a new one is on his way, but it will take a few weeks to deliver.
                              I'm not a Tech mechanic, but I try to do much myself as possible. It's quite expensive to cal a tech and fix the problem and I cant really afford that at this point.. Otherwise I would, because it's driving me crazy!
                              It seems like it has to be fixed with setting toner, as I read in the manual?
                              But I can't find this setting toner in my own country, it's nowhere to be found to buy. Even finding it in another country it's difficult to find and delivers to the Netherlands.
                              Why is it not possible to just use yellow toner? It's literal scraping the toner of the belt, so it can't get damaged because of it? Is there anything else I can use for now?
                              I hope you can help me, I've been bothering a lot of people on this forum lately Thank you
                              Regards,
                              Ilse
