Ascule Bizhub 751 streak/line on pr1nt
  • Synthohol
    Certified Konica Expert
    • 5824
    [CQ] Ascule Bizhub 751 streak/line on pr1nt
    the dumbest thing i ever saw on a forum was typing the word Print and it shows in a printable view so you cant answer the thread or open attachments.
    please fix the forum admin? WTF?
    anyway, heres the thread reposted so others can reply.
    BizHub 751 Streak/Line on Print
    Printable View
    • 02-13-2018
      Ascule
      2 Attachment(s)
      New to the forum.
      I searched for my issue before posting, didn't find anything that helped my specific issue.
      I have a consistent streak at the bottom of every print regardless of paper type/size.
      I scanned a printout. The streak has been lightened quite a bit, but you can still see the location of the streak. Its actually visible the across the entire image.
      (See attached pdf)
      I've found a few manuals for the 751, but nothing that gets into troubleshooting very deeply at all. Best I've found was a user manual that said to basically "clean the glass".
      Found a service manual on here. While very indepth with exploded parts listing, there isn't much at all about troubleshooting.
      I found a roller loose on what appears to be an imaging unit (again I don't know because I can't find a manual to confirm the name). The roller was detached on one side and jammed. Theres burned toner on the roller that can be seen on the pic. I tried to scrape it off but its very well burned in.
      (See attached image for re-attached roller)
      Any help is appreciated.
  • Synthohol
    • 5824
    Re: Ascule Bizhub 751 streak/line on pr1nt
    i'd replace the damaged parts and make sure everything fits correctly.
